Brief Description: Finished Riveting the Left Horizontal stabilizer
Finished riveting all of the left side of the horizontal stabilizer. I had to buck the main spar and center rib but was able to squeeze the outside (706) and inside (405 and 404). I made sure to leave the holes open on the inboard side that will be used to attach the fairing when the horz stab is installed on the fuselage. As I haven't done any riveting on the right side I left a few holes towards the back of assembly to give room to slide in the rear spare. This rivets will be easy to get ahold of with the squeezer once I'm ready for them. It was good just to finally pull clecos out of something knowing they will never go back in.
Forward spar bucked rivets
Blue tape helps keep the squeezer and bucking bar from slipping and prevents scratching
