JUSTIN'S WEB SITE
Date:  8-20-2011
Brief Description:  Prime
Primed the parts I cleaned last night and threw a little extra on the pieces I had done previously. Pretty easy process once you have everything cleaned. I found that when spraying with a rattle can it works better to spray a real lite coat on first then let it dry a few minutes and become tacky then spray it on heavier. I then will let it sit for a good thirty minutes and hit any spots I missed or that might need more (mating surfaces).
