Brief Description: control rods, elevator spring, misc
Primed and drilled aluminum tubes for the long in wing airleron control tubes. The bolts are on order from Mcmaster Carr. Updrilled and deburred both aileron control paddles. pressed bushings into 4 m5 bearings and attached to aileron pushrods. Attached pushrods to paddles. Adjusted and attached elevator return spring to elevator bellcrank and riveted spring retainer to fuselage floor.
