Brief Description: rudder cable fairleads and safety hinge pins
Today I drilled and riveted the rear rudder cable fairleads to the fuselage. I also decided to saftey the hinge pins in place using a spare piece of hinge to hold the pin in place. Photo 2 shows where I will be securing the elevator hinge pins and photo 3 shows where I have secured the rudder hinge pin to one of the bottom longerons. I will rivet the elevator hinge pin in place when I am sure I will not need to remove the elevator for a whiile.
