I am putting in a Dynon AOA pitot. I cut the hole for the mast and had to fabricated a backing plate .063 thick to make up for the difference in the RV spar and the Panther spar. Drilled and clecoed the mast per Dynon instructions.Also drilled and tapped pitot tube to attach it to the mast
