Brief Description: Assemble and match drill the left fuel tank
I started out by putting in the routing for the fuel level sender. After riveting (see other entry for today), I started assembling the left fuel tank. It took a lot of work to get the ribs started but I eventually got them all in place and then match-drilled them and the stiffeners. Nest, I installed the J-stiffener and then I skipped the fuel filler and added the last rib half. Everything was match-drilled; now I need to check a few things before I continue.
