Brief Description: Build wing cradles, correct some previous work
Cut the parts for the wing cradles. I borrowed some time on Jack Keegan's bandsaw to cut out the inner part. I then drilled for 1 x 2 poplar spacers and screwed the cradles together. Then I applied some weather strip inside the cutouts and taped the top part.
While I was doing that, Brad Ransom dropped by so I showed him the progress. Naturally I discovered that I had clecoed the forward wing walk upside down and had forgotten to dimple a few locations where the J-stiffener runs between the wing walk doublers. Fortunately, I was the one who noticed them. So, off came the inboard wing while I flipped the forward doubler over and dimpled the holes I missed. Then I clecoed the skin back on.
