Brief Description: Fabricate hoses from A/C to compressor
After failing the installation previously, I had ordered new hoses and clamps. This time I started with the fill fittings, which were much easier to assemble outside the airframe. Once assembled and clamped, I threaded them into the airframe.
I also glassed over the balsa shim in the canopy overhead, to facilitate adding click-bond studs, and added a layer of glass behind the openings in the overhead for vents to allow enough thickness for the clamping rings on the vent bodies to get purchase.
