Patrick Kelley (Flion)
Date:  5-29-2012
Number of Hours:  5.00
Manual Reference:  32-5, 35,2
Brief Description:  Rivet Right Rear Floor, Fuselage Join
Actually, today was a bit of a miscellaneous day. I started out by finishing up the cut in the Right Rear Seat Pan and, in the process of cleaning up so I could continue working on the baggage area, I ended up riveting the perimeter of the Right Rear Floor that I had previously riveted into place to the stiffeners. I also did some planning for the ground power receptacle and the Oxygen fill.
Then Phill Cobbin made the mistake of showing up, so I Shanghaied him into helping me finish riveting the fuselage to tail joint. It was pretty straight-forward but I had been unable to do it before this without a riveting partner. Thanks, Phil.
Rivet count: 112 Total: 15547 - Plus 549 done at Van's
