Brief Description: rivet rear spar, cleco top skins on right wing
Cut out the hole in the doubler for the aileron pushrod and clecoed it back to the spar to finish matching the hole to the spar. Drilled out the clecoed rear spar and disassembled the parts after countersinking the bottom row on the inboard doubler. Cleaned up all the edges and deburred everything and then primed the doublers and fork With everything clecoed back to the wing, I riveted the rear spar in place. To finish off, before going to PHX with Judith, I laid the top J-stringers in place and then clecoed the top skins and wing walk doublers to the wing structure.
Rivet count: 140 Total: 9885 - Plus 549 done at Van's
