Patrick Kelley (Flion)
Date:  6-1-2011
Number of Hours:  4.80
Manual Reference:  16-2.5 & 6
Brief Description:  Dimpling left wing skins for riveting
Dimpled the rest of the wing skeleton. While I was at it, I riveted the pitot heat mount to the rib and then installed the control. The first two pictures show the mount and the cover. I also dimpled the outboard J-stringer.and set it into position.
I peeled the plastic from the inside of the outboard skin. I trimmed the forward inboard corner the same way I did the inboard skin yesterday. Then I dimpled the entire outboard skin and then primed the filed corner. Finally, I clecoed the skin to the skeleton progressively, peeling the outside blue plastic as I went.
Rivet count: 10 Total: 6998 - Plus 549 done at Van's
