Brief Description: Fabricate wing ribs and begin left wing assembly
Cut the angle and spacer pieces for the 1010 ribs for both wings. Drilled the spacers to their respective bellcrank parts and then assembled the bellcrank halves with the VA-146 bearings. Added the assemblies to their respective ribs, clamped the angle pieces, and drilled them in place. Then match-drilled the rest of the assembly. Added the flap hinge support and 1025B to both ribs but have not match-drilled yet. Also added the same parts to W-1011 ribs to make four assemblies, two left and two right. Set the ribs for both wings aside to be finished later. Trimmed the forward tabs on a W-1011R and trimmed the aft flange of a W-1012R. Clecoed all the ribs to the left spar except for the three ribs with the flap hinge support, which still need to be match drilled.
