Brief Description: Drilled left wing stiffeners using spar as guide
Just like I did on the right wing, I aligned the stiffeners using a 1/16" drill bit as a guide and side-grip clecos to hold in in place while I began the drilling. Much later, four stiffeners. Then I finished up by match-drilling the remaining #40 holes in the spar.
