Brief Description: Runup to fine tune and check RPM reading
Still troubleshooting the RPM indication. Have ordered a Westach sender to bypass the problem with the Lightspeeds for now. Ran up the engine to verify that the oil leaks were fixed and to test the other sensors. Removed the cowlings and verified that all connectors and fittings were tight and inspected the controls for the Airflow Performance injection.
