Reinstalled flap mechanism. Added wiring run to under panel, with molex connector in flap motor housing. Installed housing except for left side (for airworthiness inspection). Connected wiring to P1 connector and ran flap from panel switch to determine wiring polarity. Also tested strobe and tail light at the same time. Cleaned up wiring runs to wing spar. Reinstalled canopy latch mechanism except for latch itself and the pushrod.
