aaron worked alone.tapered hs-710 and hs-714Drilled relief holes in HS-702 (x2), marked bend lines, removed flange material to bend line.match drilled hs-710 & hs-714 with the spars, hs-702Marked HS-404 front rib tip flange for material removal to clear HS-710 and HS-714 (x2)
