Freds Web Site
Pulsar XP
Fuselage CM P-92
Mounted Slide Pin on Canopy
Started at 11:00am and Stopped at 2:00pm
Drilled 1/2 inch hole in plywood block and inserted the slide pin.
Drilled a 3/32 inch hole through the plywood block and slide pin.
Cut the heads off 2 bolts and ground them into bullet shapes.
Bonded the bolts into the aft canopy frame.
Page 92 Steps 6-7 and Page 94 Steps 8-9
Pulsar XP Home
284
62
Inventory and Inspec
Vertical Stabilizer
