Freds Web Site
Pulsar XP
Fuselage CM P-76
Completed aft access door
Started at 11:00am and Stopped at 5:00pm
Sanded aft access door opening and door.
Drilled corner holes in the access door.
Fitted fittings to the corner plates and rivited 3 corners.
On inspection the forth corner plate was not bonded well, so it was removed, surfaces prepared and the corner plate was rebonded.
The com antenna was constructed and placed in the leading edge of the verticzl stabilizer along with coax cable.
Pulsar XP Home
284
62
Inventory and Inspec
Vertical Stabilizer
