Mark out template for instrument panel - including instruments required Make fuel tank support brackets - drilling and welding Design and draw up electrical circuit in CAD Make templates for side panels Initial sand instrument and firewall bow Review STA11 rib profile drawings and check Cut out 5/6" nose on sta22 - typ2 Cut 5/16 spruce rib pieces - one rib Cut other rib pieces and glue first rib Dress first rib and cut out 1.5mm ply - glue second rib - cut 1.5mm ply sides Remove rib from jig and dress back - redraw STA23 and 35 ribs Bend spar fittings and review hinge detail - make up sample 7075 hinge Dress spar fittings to correct shape - make rudder 2.5" block and glue end turtle deck former Manufacture hinge blanks from 4130 RHS
