Grind and drill hinges Drill holes for rudder and elevator cable brackets and 9/32" hole in stabiliser Braze 2 hinge assemblies Braze 3 hinge assemblies Dress hinge assemblies on sander Layout instrument panel - print template Make 1/4" elevator connection blocks Review fuel tank and fuel sender installation Design and draw up engine mount Firewall cut out front panel and cross members Firewall work Top fuselage panels glue 3/4 x 3/8" members- draw ucarriage bracket 4140 Machine up 4140 engine mounting points - 8off Deburr engine case - check fuel tank installation and varnish Firewall varnishing rudder supports and stabiliser 1/4" mounting plates Drill and glue stabiliser for 1/4" top plates - varnish firewall and elevator Engine mount jig and tube Engine mount Engine mount Engine mount and glue firewall ply to structure
