Frank's Panther Cave
Date:  8-1-2008
Number of Hours:  51.00
Brief Description:  Fuselage
August work completed
Grind and drill hinges
Drill holes for rudder and elevator cable brackets and 9/32" hole in stabiliser
Braze 2 hinge assemblies
Braze 3 hinge assemblies
Dress hinge assemblies on sander
Layout instrument panel - print template
Make 1/4" elevator connection blocks
Review fuel tank and fuel sender installation
Design and draw up engine mount
Firewall cut out front panel and cross members
Firewall work
Top fuselage panels glue 3/4 x 3/8" members- draw ucarriage bracket 4140
Machine up 4140 engine mounting points - 8off
Deburr engine case - check fuel tank installation and varnish
Firewall varnishing rudder supports and stabiliser 1/4" mounting plates
Drill and glue stabiliser for 1/4" top plates - varnish firewall and elevator
Engine mount jig and tube
Engine mount
Engine mount
Engine mount and glue firewall ply to structure
