Daniels Web Site
Date:  11-14-2016
Number of Hours:  2.60
Manual Reference:  PAP G4
Brief Description:  PAP - G4 - Engine Check
All of the steps in this section passed with some specific notes as follows:
Filled cooling system with Prestone Dex-Cool 50/50 Extended Life coolant. This coolant is called out in SI-912-016R8.
Filled and purged oil system with Aeroshell Sport Plus 4 in accordance with SI-912-018R1. Air pressure applied to oil tank by setting up regulator and hose at bottom of oil vent tube.
With fuel added to tank and pump turned on, no leaks and fuel pressure at 3.2 PSI.
Checked fuel flow with battery voltage at 12.4v (spec is 12.7v). Time to pump 1 gallon of fuel was 143 seconds (spec is no more than 180 seconds).
SECTION G4 IS COMPLETE
Oil Purge Setup - Top of Oil Tank
Oil Purge Air Regulator Setup
Coolant Filled Up
Coolant Filled Up
