Daniels Web Site
Date:  5-22-2016
Number of Hours:  0.90
Manual Reference:  32-06
Brief Description:  Complete & Adjust Flaperon Control Rods
Installed the nuts and rod ends on the ends of the flaperon control pushrod and adjusted to 38 3/4 inch per KAI page 32-06.
Since section 32 was completed before the revision came out that drilled the flaperon torque tubes to have a slight droop on the flaperons, both control rods were lengthened between 1/16" and 1/8" so there will be droop when wings are installed. Will have to check the droop during PAP and adjust rods again, if necessary.
New Control Rod
New Control Rod
Both Control Rods
Both Control Rods
