Daniels Web Site
Date:  2-9-2013
Number of Hours:  2.80
Manual Reference:  NA
Brief Description:  Re-Installed Landing Gear (SB 12-11-09)
Step 43
Lightly coated inboard and outboard gear legs where contact is located on wear plates.
Step 46
Manuevered each gear leg and outboard main gear attach brackets into position and loosely installed AN5-22A bolts, washers and nuts.
Step 47
Installed U-1203B inboard wear plate, U-1203E inboard doubler plate, U-1203 inboard main gear attach bracket, and U-1203C doubler plate. Tightened and torqued AN6-25A bolts and then AN-24A bolts. Tightened outboard bolts but did not torque yet. Need to find aa way to get on nuts to final torque.
Step 50
Reconnected caliper brake lines to associated fittings on U-1203 inboard main gear attach brackets. Used Locktite 567 thread sealant per page 35--04, step 4.
Assuming the Position!
Bolted Up - Top of Center Section
Outboard Main Gear Attach Bracket
