Daniels Web Site
Date:  1-21-2013
Number of Hours:  1.40
Manual Reference:  NA
Brief Description:  Countersunk Outboard Wear Plates (SB 12-11-09)
Step 40 (erroneously marked as step 34 in SB)
Deburred 1/4" holes in center section, U-1202C-B outboard doubler plates and U-1202D-B outboard wear plates.
Step 41
Cleaned up drill shavings.
Step 42
Machine countersunk holes on bottom sides of U-1202D-B outboard wear plates. Used scrap AN4 bolt to align holes in drill press. Cut with 100 degree countersink using machine oil. Verified that AN509-416R17 screw head sits flush with wear plates.
Drill Bit Centering Hole
Countersinking Hole
Countersinking Hole
Countersink Results
Countersink Results
