Daniels Web Site
RV-12
SB121109_ctr_mod
1-14-2013
NA
Match Drilled Side Skin Doublers (SB 12-11-09)
Step 20
Removed blue vinyl plastic from mating surfaces and clecoed F-1270A and F-1270D side skin doublers to sides of fuselage.
Step 21
Match drilled holes in F-1270A and F-1270D side skin doublers into sides of fuselage and adjoining structure.
RH Side Skin Doubler Match Drilled
RH Side Skin Doubler Removed
Drilled Holes (RH Baggage)
RV-12 Home
1273
00 - AOA
00 - Completed Kits
00 - Kit Inventory
00 - Mice Damage
00 - Miscellaneous
00 - Move Aircraft t
00 - PAP
00 - Upholstery
00 - Wing Play
06 - Vertical Stab
07 - Rudder
07A - Rudder Trim Ta
08 - Anti-Servo Tab
09 - Stabilator
10 - Tailcone
11 - Emp Attachment
12 - Emp Fairings
13 - Spar Assembly
14 - Rear Spar, Stub
15 - Wing Ribs
16 - Stall Warning
17 - Wing Skins
18 - Flaperon
20 - Center Section
21 - Mid Fuse Ribs &
22 - Fwd Lwr Fuselag
23 - Side Skins
24 - Rollover Struct
25 - Tailcone Attach
26 - Seat Backs
27 - Rudder Pedals &
28 - Fuel System
29 - Fwd Upper Fusel
30 - Wing Attachment
31A - Wing Elec Upda
31B - Fuselage Wirin
32 - Flight Controls
33 - Miscellanea
34 - Canopy
35 - Landing Gear &
37 - Fuel Tank
37B - Tank Vent Mod
38 - Cowling
39 - Autopilot Servo
40 - Lighting
42C - Skyview Avioni
42D - Skyview Update
42F - ELT
42G - GTR200
42M - Control Module
44A - Autopilot Serv
45A - Firewall Wirin
46 - Engine
47 - Propeller
48 - Exhaust
49 - Cooling
50 - Controls
51A - Documentation
52 - Tow Bar
53 - ADS-B
54 - Stiffener Retro
58 - Skyview AP-Knob
N140514_stab_rib_cra
N140522_canopy_latch
N140910_ELT_GPS_data
N150915_spar_switch
N160810_soft_eng_iso
N161104_Canopy_Strut
notify_sv_wire_swap
SB121109_ctr_mod
SB130405_oil_tank
SB131212_seal_av_bay
SB131219_fuel_attach
SB141103 - Wing_Doub
SB141206_bearing_bkt
SB160824_eng_mnt_riv
