Daniels Web Site
Date:  8-1-2011
Manual Reference:  20-xx
Brief Description:  Match Drilled New Center Section
Back from Oshkosk. While gone, received the new F-1204 Center Section Assembly. Part was unpacked and inspected for damage. No damage noted.
For the record:
F-1204 Center Section Assembly - SN #0464
Accomplished match drilling of the center section aft bulkhead F-1204D to the new center section F-1204 (page 20-02, step 4 and page 20-03, steps 1 through 3). This one turned out much better with the upper edge of the F-1204D bulkhead aligning with the top of the F-1204 center section with no deviation. Much happier with this one. In retrospect, very happy with my decision ($517) to replace the center section instead of trying to make the original center section work with possible issues later in the build.
F-1204 Center Section SN #0464
F-1204D Bulkhead Aligned with Center Section
Match Drilled Results
