Daniels Web Site
Date:  4-16-2012
Number of Hours:  0.80
Manual Reference:  31B-25
Brief Description:  Wiring - Wireway Bracket Flange
I was so excited that I got the rudder pedals working correctly, that when I got to this page, I had to remove the bolts from the middle rudder pedal blocks to install the wireway bracket flange. Successfully done that without losing washers between the block halves. Denise helped by getting the tie wrap started in the bracket flange and around the wire harness. Secured tie wrap. (page 31B-25, step 4).
Wire Harness Secured to Flange
Denise Assuming the Position
