Daniels Web Site
Date:  8-12-2016
Number of Hours:  1.00
Manual Reference:  37-09 (R1)
Brief Description:  Install Fuel Tank
Installed fuel tank and secured forward end with frangible bolts (BOLT-00002). Torqued to 30 inch-pounds and torque striped. Temporarily installed AN4-6A bolt at aft attach angle - need to order AN4-4A bolt for final install. Attached and tightened fuel line and fuel return line at bottom of tank. Hand-tightened B-nuts then tightened an additional quarter turn. (step 1 - partial)
Hardware references are on page 37-07 (R4).
Installed fuel sender wire to fuel sender. (step 3).
UPDATE 9-16-16
Finally ordered AN4-4A bolt. Removed AN4-6A bolt from aft fuel tank attach point, installed AN4-4A bolt and washer, then torqued to 60 inch-pounds.
Frangible Bolts Installed
Fuel Vent Line Connected
Fuel Line and Fuel Return Connected
