Daniels Web Site
Date:  12-27-2016
Number of Hours:  2.60
Manual Reference:  PAP G6
Brief Description:  PAP - G6 - Check For Debris
Removed gascolator drain and strained fuel through a coffee filter. Minor swarf was noticed and looked like very fine flakes of aluminum. Probably stuff left in the fuel lines/tank during construction. Very happy with the minimal amount found.
Drained the remaining fuel from fuel tank (about 2 gallons) and also strained through a coffee filter. A few small dirt-looking particles were captured. Looked more like small pieces of fuel tank sealant. Probably some left in tank from scraping during fuel tank doubler mod.
The gasolcator screen had a very thin layer that easily wiped off with a rag. It looked more like fuel being retained in the screen - no obvious other debris.
Re-installed screen and gascolator and safety-wired.
Removed both carb bowls and strained fuel through a coffee filter. Very minor black material caught. Again, probably small pieces of fuel tank sealant.
SECTION G6 IS COMPLETE
Minor Swarf From Gascolator
Minimal Debris in Carb Bowls
Gascolator Safety Wired
