All of the steps in this section passed with some specific notes as follows:
The second step that N numbers are 12 inches are NA since aircraft is E-LSA, not S-LSA). Three inch N numbers are used on the vertical stabilizer on each side.
Verification of ELT wording a bit misleading. There is no adjacent ELT label required per KAI page 51A-02 that says "PLACARD ONLY REQUIRED FOR ARTEX ME406 ELT" ACK ELT installed. The ELT panel does have a label that was installed as part of the panel.
