Daniels Web Site
Date:  1-21-2017
Number of Hours:  2.60
Manual Reference:  34-xx
Brief Description:  Install Canopy Front & Side Seals
Page 34-17
Fabricated base seals, temporarily positioned on panel base, and added reference marks on fuselage side skins. (steps 4 through 8)
PAGE 34-17 IS COMPLETE
Page 34-19
Checked space between canopy frame and canopy deck and determined that foam spacer not required, then cleaned underside of canopy square tubes with alcohol. (steps 1 & 2)
No foam spacer required so step 3 is NA.
Transfered reference mark on fuselage side skin to canopy square tube. (step 4)
Measured, cut, and installed both side seals on each canopy square tube. (steps 5 through 7)
PAGE 34-19 IS COMPLETE
Page 34-20
Lightly sanded underside of canopy fiberglass layup to remove rough spots, then cleaned with alcohol. (steps 1 and 2)
Measured, cut, and installed forward seal under fiberglass layup along forward edge. (steps 3 through 7)
Applied modeling clay on upper forward fuselage skin in area where canopy forward seal hits and marked location on upper forward fuselage skin. (step 8)
Cut seal curvature template, held in place on each side, and marked reference line on canopy ribs. (steps 9 and 10)
PAGE 34-20 IS COMPLETE
Page 34-21
Cleaned panel base with alcohol, applied red RTV at canopy rib intersection, and installed previously fabricated base seals. Plans called for clear silicone sealant but used red RTV since that's what I had. (steps 1 through 4)
Temporarily held canopy rib vertical seals in position, pushed at edge of upper forward fuselage skin to mark height, then cut 1/4" longer than mark. (step 5)
PAGE 34-21 IS COMPLETE
Page 34-22
Using canopy rib vertical seals as is (not using alternative 3M 1099 adhesive - rest of step 1 is NA). Applied red RTV at lower end of base seals and peeled backing from vertical seals. (step 1)
Attached vertical seal, following reference mark curvature. Waiting for sealant to cure. (steps 2 and 3)
Page 34-23
Fabricated four foam plugs, folded back so adhesive held folded position, and installed in openeings at each of of canopy square tubes.
PAGE 34-23 IS COMPLETE
Base Seal
Base Seal
Seals on Canopy Square Tubing
Canopy Forward Seal & Vertical Seal
