Used craft paper to make paper templates for cowl heat shields. Prior to removing the bottom cowl on page 49-14, marked cowl in areas of cylinders #1 and #2 exhaust pipes for heat shield location. (step 1) Removed templates and scuffed cowling around edge of templates with 80 grit sandpaper. (step 2) Using templates, cut heat shields. (step 3) Started to install heat shield pieces and realized that the large bottom piece was not cut properly. Template was placed on the paper side of the heat shield and then cut causing the heat shield to be a mirror image of what was needed. The photo shows the heat shield (paper side) in position but upside down. Need to order more heat shield material and re-cut the large bottom piece. Installed the other three heat shield pieces. (step 4 - partial)
