Daniels Web Site
RV-12
37B-03
Fuel Tank Vent Mod Holes
Removal of res sender plate already done as part of SB13-12-19. (step 1)
Using template, drilled vent hole in top tank skin. Deburred hole. (step 2).
Using template, drill vent hole in baggage bulkhead. Deburred hole. (step 4).
Installation of res sender plate will be done as part of SB13-12-19. (step 5)
Vent Hole in Tank Top Skin
Template for Baggage Bulkhead Hole
Baggage Bulkhead Vent Hole
RV-12 Home
1273
00 - AOA
00 - Completed Kits
00 - Kit Inventory
00 - Mice Damage
00 - Miscellaneous
00 - Move Aircraft t
00 - PAP
00 - Upholstery
00 - Wing Play
06 - Vertical Stab
07 - Rudder
07A - Rudder Trim Ta
08 - Anti-Servo Tab
09 - Stabilator
10 - Tailcone
11 - Emp Attachment
12 - Emp Fairings
13 - Spar Assembly
14 - Rear Spar, Stub
15 - Wing Ribs
16 - Stall Warning
17 - Wing Skins
18 - Flaperon
20 - Center Section
21 - Mid Fuse Ribs &
22 - Fwd Lwr Fuselag
23 - Side Skins
24 - Rollover Struct
25 - Tailcone Attach
26 - Seat Backs
27 - Rudder Pedals &
28 - Fuel System
29 - Fwd Upper Fusel
30 - Wing Attachment
31A - Wing Elec Upda
31B - Fuselage Wirin
32 - Flight Controls
33 - Miscellanea
34 - Canopy
35 - Landing Gear &
37 - Fuel Tank
37B - Tank Vent Mod
38 - Cowling
39 - Autopilot Servo
40 - Lighting
42C - Skyview Avioni
42D - Skyview Update
42F - ELT
42G - GTR200
42M - Control Module
44A - Autopilot Serv
45A - Firewall Wirin
46 - Engine
47 - Propeller
48 - Exhaust
49 - Cooling
50 - Controls
51A - Documentation
52 - Tow Bar
53 - ADS-B
54 - Stiffener Retro
58 - Skyview AP-Knob
N140514_stab_rib_cra
N140522_canopy_latch
N140910_ELT_GPS_data
N150915_spar_switch
N160810_soft_eng_iso
N161104_Canopy_Strut
notify_sv_wire_swap
SB121109_ctr_mod
SB130405_oil_tank
SB131212_seal_av_bay
SB131219_fuel_attach
SB141103 - Wing_Doub
SB141206_bearing_bkt
SB160824_eng_mnt_riv
