Daniels Web Site
Date:  7-2-2016
Number of Hours:  1.10
Manual Reference:  42M-04, 05, 08, 09
Brief Description:  Control Module Miscellaneous
Page 42M-04
Machine countersunk attach screw holes for center panel. (step 1). Also, drilled 1/2" autopilot disconnect switch hole.
Page 42M-05
Drilled 1/4" hole in center panel for dimmer. (step 3)
Page 42M-08
Not sure why this page is here since the steps were previously accomplished in Section 42C. Machine countersink left instrument panel and install ignition & start panel. (steps 1 and 2).
PAGE 42M-08 IS COMPLETE
Page 42M-09
Connected ignition harness between the AV-5000A control module and the ignition & start panel. (step 1).
PAGE 42M-09 IS COMPLETE
Center Panel Drilled & Countersunk
Ignition Harness Installed
