Brief Description: Complete & Adjust Flaperon Control Rods
Installed the nuts and rod ends on the ends of the flaperon control pushrod and adjusted to 38 3/4 inch per KAI page 32-06.
Since section 32 was completed before the revision came out that drilled the flaperon torque tubes to have a slight droop on the flaperons, both control rods were lengthened between 1/16" and 1/8" so there will be droop when wings are installed. Will have to check the droop during PAP and adjust rods again, if necessary.
