Daniels Web Site
Date:  4-28-2016
Number of Hours:  1.30
Manual Reference:  40-11
Brief Description:  Eyeball Cockpit Light
Been a long time since I've been in this section. Working this concurrently with Notification 14-05-22 (canopy latch warning) since wiring runs in the same area.
Step 9 makes a power and ground wire and runs them back to the panel base. Confirmed that power and ground wires already tied back near ELT and fuel sensor wiring. Confirmed that the yellow/purple wire and yellow/green wire have continuity to the OPTIONS connector pins 18 and 32 per the wiring diagram.
Step 15 - Inserted SB375-3 snap bushing in hole already drilled in roll bar attach plate.
Step 16 - Made wire tube.
Power and ground wires routed through snap bushings and out through bushing at top of roll bar. See Notification 14-05-22 entry for details.
