- Removed leading edges from left & right sides. - Center leading edge is okay; however, left & right side were damaged/dinged during prep of aft spar, prior to installing flange for elevator hinges. (Too much pressure was applied while sanding the aft spar - which put large recesses in leading edges - from the stab stand we made.) - Sanded and cleaned area, then applied thin layer of micro-paste.
