- Removed seat bottoms to expose seat bottom flanges. - Added additional micro in areas that flange did not totally adhere to supports (mostly on the leading & trailing edges. - Sanded & prepped vertical tail spar area where it meets the aft fuselage - Applied first lapyer of BID to vertical tail support with 1 1/2" overlap
