- We applied more micro to areas previously sanded to fill low areas. - Large areas on both sides of curved area near tail-end filled with micro; they were slightly flat on the bend. - Applied a small UNI patch to curved area around firewall area where sanding caused the glass to be breached. - We cut and micro'd a patch for the large curved area on bottom left side that needs to be raised up a bit. This piece will be put on after the mocro cures.
