N114FM - Vision #243
Date:  2-18-2006
Number of Hours:  1.50
Brief Description:  Sanding & Contemplating...
- Mike sanded top side micro
- We measured tips and ribs on both sides of stab and found:
-- left side is approx. 1/4" wider (at BL 40 & BL44) than right side
- We also found and area on the right side that seems higher/thicker at BL40 than left side.
- We're contemplating adding thickness to right side (thin side) from BL30 to the tip in an effort to make it the same thickness/width as the left; HOWEVER, we need to know how thick the ELEVATOR will be at the point where it meets flush with the tips.
-- We looked in the plans and found that there's REALLY NOT a good reference for the width of the elevator at these points!
-- The plans direct you to fashion the elevator using the same method as the vertical stab...so,
-- Since we haven't built the vertical stab yet...we don't know how wide is should be at these points. (The plans refer to a BL on the VERTICAL STAB...but don't provide any templates for the ribs...
- So we've essentially stopped work until the next time Rick returns home from Florida (he leaves for Tampa tomorrow and doesn't know when he'll be returning.
