N114FM - Vision #243
Date:  2-15-2006
Number of Hours:  2.50
Brief Description:  Removed Leading Edges
- Removed leading edges from left & right sides.
- Center leading edge is okay; however, left & right side were damaged/dinged during prep of aft spar, prior to installing flange for elevator hinges. (Too much pressure was applied while sanding the aft spar - which put large recesses in leading edges - from the stab stand we made.)
- Sanded and cleaned area, then applied thin layer of micro-paste.
