Primed the pieces of the rubber. Significant improvement over what I saw on the rudder.
Used 30 psi at the gun with the trigger pulled. Also installed an additional water seperator/filter.
I did not prime the R1006 trailing edge as I wanted to prime the parts while I had the time on the weekend before I had time to countersink the trailing edge.
