Disassembled the entire HS, marking parts for location as removed. Also final drilled the HS1016 stringer web once I had access.
Started deburring the various pieces, including the rear spar. Countersunk the holes on the rear spar. This was the first piece removed and wanted to complete it before I moved on.
