Wing sweep was within 1/16 of and inch. The left wing was 0.1 degrees high on tailing tip end, root was 0.0 degrees The right wing was 0.1 degrees low on tailing tip end, root was 0.0 degrees
Fitted flaps to fuselage Cut hole for flap pushrods Adjusted flap pushrods
