I drilled and completed the spinner and bulkheads. I removed the spinner and spent the next 3 hours sanding and polishing it.
This is a Cummins aluminum spinner. I had none of the fit issues that others ran into. The rear bulkhead lined up perfectly with the as supplied front plate.
