1.0 flight time, 6x around pattern, ~0.5 maneuvering flight. Did some slow cruise flight 2700 rpm at about 125 mph indicated, medium and steep turns, slow flight with flaps, power off stall with and without flaps, then returned to the pattern and went 6x around. Bounced the 3rd one and recovered into a full stall. 15 gallons fuel, 180 lbs ballast, 205 lbs pilot ~665 lbs airplane = 1140 lbs at 66.66" aft of datum.
