Made the main 12V feed line from the switch to the fuse holder. Mounted the over voltage detector under the glare shield forwards of the intercom. Located and drilled the transponder encoder mount plate. Will simply rivet this to the glare shield. The connector for the encoder is pretty tight to the power socket for the GPS, but it works. Have to relocate existing EIS wiring to make room for the encoder.
