Cut opening for the gear leg in the RH cowling. Made several iterations of cutting it deeper because the cowling has to fit between the gear leg and the prop hub. Still haven't quite got it far enough, but I got it far enough to see that the cowling hits the oil sump fins, more so on the lower sump than at the top. Started filing on the fins using the surform body file. Will need to do more of that before continuing.
Right side going on.
Area to be trimmed in small increments until the corner of the cowling is in the right place.
