Took about an hour to secure the brakes to the axles. Had to disassemble the brakes (pull out the cams) to access the nut on the AN3-5A bolt holding the brake to the axle. Even then, the head of the bolt could not move at all and had to be held with an open end wrench, with the nut being turned about 1/12 turn with another open end wrench. One would think if you could see the head of the bolt (on the axle) that it would be an easy install, but it wasn't. Nothing show-stopping, just all the steps to disassemble the brake and put it back together. I hope they don't need to come back off anytime soon. Rest of the time was drilling the tailwheel Ti rod and various tailwheel-related parts. Just passed 900 hours of build time.
